Configures route distinguishers for an EVPN instance.
| bgp | BGP capability. |
| evpn | EVPN protocol. |
| instance | Specifies configuring an EVPN instance |
| evpn_instance_name | Specifies name of the EVPN instance. |
| rd | Specifies configuring route distinguisher. |
| rd_value | Route distinguisher in format <admin>:<assigned number>. |
| auto | Specifes auto-derived route distinguisher values (default). |
By default, auto-derived route distinguisher values are used.
The specifies auto-derived route distinguisher values for the EVPN instance "my_evpn":
# configure bgp evpn instance my_evpn rd auto Warning: Changing RD value for EVPN instance my_evpn from to 'auto calculated' instance will be reset
This command was first available in ExtremeXOS 30.2.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature,see the Switch Engine v33.1.1 Licensing Guide document.
